Cannot render thru command prompt
COW Forums : Autodesk Maya
jack halsey
on Aug 27, 2010 at 5:52:55 pm
Hello
I recently changed from Maya 2009 to Maya 2010. I uninstalled Maya 2009, cleaned the registry, and installed Maya 2010. Now at the command prompt it will not render. In Maya 2009 I used to type "render filename.mb" and it would render. Now when I type the exact same thing it states that render is not a valid command. Please advise and thank you.
