Particle Instancer problem
COW Forums : Autodesk Maya
Lewis Hackett
on Aug 18, 2010 at 5:23:04 am
Hey guys, im having trouble with particle instancing -
I have a balloon model which is a rigid body, with a parented string made from a nurbs cylinder with a wire deformer attatched to particles.
Is there a way that I can get this grouped object to instance the geometry to particles and be created at the emitter?
Each time I try, the new instances are emitted from the original group and not the particle emitter, have I missed something that solves this or is there an easier / better way?
Thanks in advance if you can rectify this shortly as I am on a tight deadline :)
© 2018 All Rights Reserved
