Wield maya tool ??
COW Forums : Autodesk Maya
hong-seok kim
Wield maya tool ??
on Aug 12, 2010 at 6:39:24 am
I have a simple and wield problem to manipulate axis.
First, I choose an simple object and press W(or E,R) to move the object.
And drag the axis...
Then the axis disappeared !! (actually, the move tool changed to select tool ! )
And I press the W(or E,R) again the axis appeared again. And drag? Soon disapeared ......
I dont't know why this happend. I deleted reference files and format my hard drive and re-install. Also tried to use new mouse...
It never cured....
If I want to continue my work, I have to press W key every single movement.....(or rotating,resizing, because it turn to select tool mode soon when I just touch my object)
The object is just simple cubic geometry(No CPU overloaded) and new scene...
Please help me... I format my driver 2 times and re-intall many times!!
PS. someone says it's the problem of motherboard.. in the specific part that related in USB.
But rest of appication are fine. Only in Maya happens (ah;;...) It can be possible?
© 2018 All Rights Reserved
