How do I adjust the speed of an animated texture?
COW Forums : Autodesk Maya
Josh Lange
on Jul 17, 2010 at 8:52:45 pm
I've mapped an animated texture to a plane and it's working fine, but it's playing too slow. Can I adjust the rate that it's playing in Maya in the attributes somewhere?
Thanks in advance...
Michiel Duvekot
Re: How do I adjust the speed of an animated texture?
on Jul 18, 2010 at 3:27:32 pm
You can, but you shouldn't. If the framerate is wrong, you cannot have the proper relationship between a frame and a file texture;
Ideally, you would have
frame1 : image.1.iff
frame2 : image.2.iff
frame3 : image.3.iff
frame4 : image.4.iff
This is what the default expression does: file1.frameExtension=frame
You could try to speed up the playback of the texture by changing the expression. For example< if I wanted a 60% increase in playback speed I could change it to
file1.frameExtension=frame * 1.6;
but then this would happen:
frame1 : image.2.iff
frame2 : image.3.iff
frame3 : image.5.iff
frame4 : image.6.iff
Which I bet is going to look horrible.
Michiel
http://www.thnkr.com
