what res should i use?
COW Forums : Autodesk Maya
mark francis
on Jun 8, 2010 at 10:20:55 am
i want to render tiffs but what res should i use if i want to import my tiff frames into fc pro or shake. i think i need dvd video pal because i live in the uk. but what setting would you recommend?
Alvaro Castaneda
Re: what res should i use?
on Jun 8, 2010 at 3:06:44 pm
Hi Mark
In this days of HD tv I usually render everything to full HD 1920x1080, and then scale down from that in my compositing or editing app, that's only if I have enough time to render that size, if not, I go for the next lower, HD720 1280x720, but if you just need the PAL widescreen version, which is actually almos HD720, this is it PAL widescreen 1024x576
there you go
have a blast
Cheers
varomix - pixelEater
http://www.intelianimate.com
mark francis
on Jun 11, 2010 at 4:00:44 pm
sorry for being an ass but can you help me further? what is the res on the attached list ive provided? i think your using a diffrent version of maya to mine. i havent rendered anything in maya before so its a little confusing. cheers
have i done this link to my attached pic right?
Alvaro Castaneda
on Jun 11, 2010 at 5:10:42 pm
Hi Mark
No problem
don't stick just to those presets Mark, you can actually type anything you want in there.
for PAL widescreen select PAL 768
and modify the width to 1024
and that's it
Cheers
