Merge multiple animations - same rig, same model into single file?
COW Forums : Autodesk Maya
jimmy davidson
on May 19, 2010 at 7:57:48 am
I'm using Maya 8.5, but I have access to Maya 2011.
How can I merge multiple animations - same rig, same model into single file?
I have 1 rig in 4 different Maya files, each with a different animation. walk, run, fly, and success.
I have separated these into different sequences ie - walk frames 1-100, run frames 101-200, fly frames 201-300 success frames 301-400
How can I merge these all into 1 file that has 400 frames? I would think this would be easy but when I use FBX format it keep overriding the existing animation even though it has a different frame set.
This should be easy right?
cheers,
jimmy
Alvaro Castaneda
Re: Merge multiple animations - same rig, same model into single file?
on May 19, 2010 at 7:52:48 pm
Hi
you could try to make an animation clip for each one and combine them in the trax editor
that'll work fine
varomix - pixelEater
http://www.intelianimate.com
