Large scene won't render...
COW Forums : Autodesk Maya
varga edmond
on May 10, 2010 at 8:54:49 pm
I am trying to render a scene about 17075x9775 pixel. But as I try in the ordinary way, Maya 2009 crashes and I get the following message:
Fatal Error. Attempting to save in
C:/User/Tom/AppData/Local/Temp/Tom.20100510.ma
I don't really know what this actually means, but in lack of another explanation I think this is because my notebooks small RAM size (2GB).
So I tried to render the scene in more peaces via command line rendering.
But I had no luck, here I get the following warning messages, and the image I get is partially illuminated, and really crappy:
D:\Projects\Ancada 2>render -x 600 -y 400 -reg 0 300 0 400 -rd c:\myrender -im test1 oneproductscene.mb
Starting "C:\Program Files\Autodesk\Maya2009\bin\mayabatch.exe"
mental ray for Maya 10.0
mental ray: version 3.7.1.26, Jul 30 2008, revision 26576
Warning: line 1: Unrecognized node type for node '_spotLight1_mrLoc'; preserving
node information during this session.
Warning: line 1: Unrecognized node type for node '_spotLight2_mrLoc'; preserving
Warning: line 1: Unrecognized node type for node '_areaLight1_mrLoc'; preserving
Warning: line 1: Unrecognized node type for node '_spotLight3_mrLoc'; preserving
File read in 6 seconds.
Warning: line 1: mental ray now supports native area lights, 'spotLightShape1' c
an be converted using 'mentalrayConvertToAreaLight spotLightShape1', all lights
can be converted using 'mentalrayConvertToAreaLight -all'
Warning: line 1: mental ray now supports native area lights, 'spotLightShape2' c
an be converted using 'mentalrayConvertToAreaLight spotLightShape2', all lights
Warning: line 1: mental ray now supports native area lights, 'spotLightShape3' c
an be converted using 'mentalrayConvertToAreaLight spotLightShape3', all lights
Result: oneproductscene.mb
Total Elapsed Time Since Start Of Maya (hh:mm:ss): 00:00:13
Resource Usage At Start Of Rendering
69924 Page faults
270.195 Mb Max resident size
269.227 Mb Peak total size(Estimated)
49.255 Mb Peak arena size
270.195 Mb Current
7.692 Mb Transforms
11.250 Mb MEL
30.000 Mb Data Blocks
0.214 Mb Arrays
0.016 Mb Pixel Map
0.002 Mb arguments
Rendering using 2 threads.
Automatic near/far clipping values: 0.1, 388.011.
Starting Rendering c:/myrender/test1.iff.
Constructing shading groups
Rendering current frame.
Frame triangle count: 0
Resource Usage At End Of Frame
269535 Page faults
313.313 Mb Max resident size
272.152 Mb Peak total size(Estimated)
52.588 Mb Peak arena size
508.133 Mb Current
7.692 Mb Transforms
2.211 Mb Render Geometry Arena
11.250 Mb MEL
0.214 Mb Arrays
0.002 Mb arguments
3.333 Mb Render Cache
0.016 Mb Pixel Map
// Maya exited with status 1
Could someone help me?I was searching for a solution, but after several hours I loose all hope.
Regards
Michiel Duvekot
Re: Large scene won't render...
on May 10, 2010 at 10:00:02 pm
Try mr proxies. They can help bring down the memory requirements significantly.
Michiel
http://www.thnkr.com
varga edmond
on May 11, 2010 at 2:46:46 pm
Ok, I decided to reduce the size of the scene to 8000x4000 pixel, but I still have to use batch rendering. This time it renders quite fast, the only problem is that I get the following warning messages, about a glitch regarding to my lights, which are no more visible in my final render:
Warning: line 1: Unrecognized node type for node ‘_spotLight1_mrLoc’; preserving node information during this session.
So I went back into maya and disabled the “use light shape” and then I get no warning, but my scene is under exposed plus my lights are no more visible, due to the lack of the extra boost that this option gave to the lights.
Why batch rendering supports no mental ray area lights?I was looking for a solution but I did not find anything, I have no more ideas what to do…
It is a really important project, and I don't know how to fix it, please help me out...
Render results:
Starting “C:\Program Files\Autodesk\Maya2009\bin\mayabatch.exe”
Warning: line 1: Unrecognized node type for node ‘_spotLight2_mrLoc’; preserving
Warning: line 1: Unrecognized node type for node ‘_areaLight1_mrLoc’; preserving
Warning: line 1: Unrecognized node type for node ‘_areaLight5_mrLoc’; preserving
File read in 5 seconds.
Warning: line 1: mental ray now supports native area lights, ‘spotLightShape1’ c
an be converted using ‘mentalrayConvertToAreaLight spotLightShape1’, all lights
can be converted using ‘mentalrayConvertToAreaLight -all’
Warning: line 1: mental ray now supports native area lights, ‘spotLightShape2’ c
an be converted using ‘mentalrayConvertToAreaLight spotLightShape2’, all lights
Result: scene.mb
Total Elapsed Time Since Start Of Maya (hh:mm:ss): 00:00:12
69805 Page faults
269.836 Mb Max resident size
269.043 Mb Peak total size(Estimated)
269.836 Mb Current
7.692 Mb Transforms
11.250 Mb MEL
0.214 Mb Arrays
0.002 Mb arguments
0.016 Mb Pixel Map
Starting Rendering D:/temp/scene.tif.
Glow: Filter Width = 21
Resolution = 0.638943
Halo: Filter Width = 51
Resolution = 0.260847
Frame triangle count: 7552
22414 Page faults
306.461 Mb Max resident size
303.605 Mb Peak total size(Estimated)
77.433 Mb Peak arena size
306.461 Mb Current
20.901 Mb File Texture Mipmaps
7.692 Mb Transforms
0.214 Mb Arrays
11.250 Mb MEL
0.013 Mb Render Geometry Arena
6.667 Mb Render Cache
0.002 Mb arguments
0.016 Mb Pixel Map
Postprocessing rendering result.
Glow intensity normalization factor = 0.179772.
Halo intensity normalization factor = 1.18851.
Time For Tessellation (hh:mm:ss): 00:00:00
Time For Shadow Map (hh:mm:ss): 00:00:00
Time For Post Process (hh:mm:ss): 00:00:00
Time For Frame Render (hh:mm:ss): 00:00:08
Finished Rendering D:/temp/scene.tif.
Resource Usage At End Of Rendering
1026 Page faults
308.648 Mb Max resident size
307.551 Mb Peak total size(Estimated)
76.823 Mb Peak arena size
306.992 Mb Current
7.692 Mb Transforms
0.214 Mb Arrays
11.250 Mb MEL
0.002 Mb arguments
0.016 Mb Pixel Map
Total Time For Render (hh:mm:ss): 00:00:09
Total Elapsed Time For Maya (hh:mm:ss): 00:00:21
Scene scene.mb completed.
Thanks!!
varga edmond
on May 11, 2010 at 3:47:02 pm
I think I have found a solution, :)
Until now I used to render the scene without specifying the renderer (I think the batch render should follow the original settings made inside maya, but he rendered using maya software render):
C:\render scene.mb
So I have tried this, and now the scene looks ok, even if I get the warnings:
C:\render -r mr scene.mb
Thanks.
