Maya crashes when trying to render bigger resolution than...
COW Forums : Autodesk Maya
varga edmond
on May 5, 2010 at 7:15:00 am
Could somone help me out here??My problem is that maya crashes if I try to render a image bigger then 13000x7000. But the resolution I need is 17070x9775. When I try to render the scene I get this message:
"Fatal Error. attempting to save in
c:\User....\application data\temp "
Why??
Regards. :(
Michiel Duvekot
Re: Maya crashes when trying to render bigger resolution than...
on May 5, 2010 at 1:26:38 pm
You're probably running out of memory. Likely solution: buy more RAM.
varga edmond
on May 5, 2010 at 5:57:15 pm
Thanks for the suggestion...I was thinking to the same thing...
Regards,
vedtam
