Moving Multiple faces along their normals
COW Forums : Autodesk Maya
toby Whiting
on Apr 28, 2010 at 11:17:13 am
HI,
I have an architectural building i am prepping for prototyping, all the windows have been extruded out
of the surface and i need to inset them.
I have resigned myself to the fact that i am going to have to make a selection of every window ( several hundred ) but i can't work out for the life of me how to move them all back along their normals at .
essentially i want the functionality you would get from extruding the selected but without adding any extra faces.
I am using maya 2009.
please HELP!
Thanks in advance!
Michiel Duvekot
Re: Moving Multiple faces along their normals
on Apr 28, 2010 at 2:10:35 pm
That's easy to script:
float $scale = 0.5;
string $sel[] = `ls -sl -flatten`;
string $tmp;
for ($tmp in $sel) {
select -r $tmp;
string $n[] = `polyInfo -fn $tmp`;
string $buffer[];
string $numTokens = `tokenize $n[0] $buffer`;
float $x = float($buffer[2]) * $scale ;
float $y = float($buffer[3])* $scale ;
float $z = float($buffer[4])* $scale ;
move -r -ls -wd $x $y $z;
This moves all selected faces along their normal by 50% of the magnitude of the normal vector. It would be trivial to make this do what you need.
toby Whiting
on Apr 28, 2010 at 3:39:08 pm
Genius!
Thanks Michiel.
Just tried your script on a quick box model and it works exactly as i need.
I had forgotten to mention that the model is tessellated and that each window is made up of two
triangles, when i apply the script to the building it looks like it is averaging the two triangles that make up the windows and i am getting some strange results.
Is there any way to combat this?
cowcowcowcowcow
Michiel Duvekot
on Apr 28, 2010 at 5:54:00 pm
You should be able to run [Polygons] Mesh->Quadrangulate on the selection that you were going to edit. So do that first, then run my script.
