Maya Beginner
COW Forums : Autodesk Maya
Kevin Williams
Maya Beginner
on Apr 27, 2010 at 4:00:08 am
I am trying to draw a curve and extrude it into a 3d shape that has all its sides. When I extrude my curve, all I get is a tunnel of the shape, open at each end, any help please. Maya 9 beginner.
Michiel Duvekot
Re: Maya Beginner
on Apr 27, 2010 at 3:18:01 pm
RMB (Right Mouse Button) click on the surface, go to isoparm and select the open border. Then go to [Surfaces] Surfaces->Planar.
Kevin Williams
Re: Maya Beginner
on May 5, 2010 at 2:11:21 am
When I RMB click on the curve I get Curve Point, Object Mode, Hull,Edit Point, Control Vertex,and the larger menu below it. Don't see isoparm.
Michiel Duvekot
Re: Maya Beginner
on May 6, 2010 at 10:34:08 am
Surves don't have isoparms. Select the surface.
Kevin Williams
Re: Maya Beginner
on May 6, 2010 at 12:26:56 pm
How? I made a Create>CV Curve Tool> then right click>holding down, I don't get the isoparm choice!!! Should I make my curve some other way?!?
Lost
MAYA 2009
