Question about the difference from Maya2008 and Maya2010.
COW Forums : Autodesk Maya
Dario Cavallo
on Apr 7, 2010 at 4:41:08 pm
I have followed the entire tutorial about:
"Digital Tutors – Rigging Cartoon Vehicles in Maya"
In the chapter 52, at the end of the movie, the author digits the MEL script called:
"smooth_div_connect.mel"
OK!
After that, in Maya2008 it enter in one Toolbar field, this little word:
polySmoothFace'
1) I haven't understood where is this void white field in Maya2010, because seems that from Maya2008 version to Maya2010 version, this field was deleted.
- Is this field a miniscript window?
- What is this little field?
2) In wich consists this word command " polySmoothFace' "?
- This command apply a face smooth?
- Or it is the same command that is in the menu Polygons>Mesh>Smooth?
- It apply a second "REALLY_High" smooth level?
Please see this screenshot about my problem:
Thanks for a response!
Horsepower.
Dario Cavallo
Re: Question about the difference from Maya2008 and Maya2010.
on Apr 7, 2010 at 4:59:38 pm
After that it appears this Node in the Channel Box:
3) What is this "Node" that appears in the Channel Box?
polySmoothFace107...
Method:Exponential
Continuity:1
Divisions:1
etc...
Dario Cavallo
on Apr 8, 2010 at 10:17:11 am
Ok!
I have found the solution:
Prior to all delete all instances of polySmoothFace Nodes, to avoid double smoothing to the polygons!
- In Toolbar Switch from AbsoluteTransform box to SelectByName
- Enter in the white field the word " polySmoothFace* "
All the polySmoothFace Nodes are now selected.
- Press Delete keyboard
After that:
1) In Toolbar Switch from AbsoluteTransform box to SelectByName
2) Enter in the white field the word " polySmoothFace* "
3) With this selection active Execute the MEL Script " smooth_div_connect.mel "
Now the level of the smooth is correct; and with the circle control rig "cc_drive01" selected, you can switch from "Low" to "High" and to "REALLY High" level of smoothing!
