replace object
COW Forums : Autodesk Maya
Frank Rieder
replace object
on Mar 26, 2010 at 12:54:39 am
How can I replace an animated object (group of polys) with
another group of objects. I would like to keep all the deformers
and so, just change the main object.
Frank
Michiel Duvekot
Re: replace object
on Mar 26, 2010 at 1:15:39 am
Use the deformer command to add geometries to an existing deformer
This is straight from the docs:
// To create a plugin of type "squash" on the selected object.
// First, load the plugin. The deformer command will not autoload
// your plugin. Then, select the geometries that you'd like to deform,
// and use the deformer command as follows. For example, to deform a
// cylinder with a squash:
cylinder -ax 0 1 0 -r 1 -hr 10 -d 3 -s 8 -nsp 20 -ch 1;
select -r nurbsCylinder1;
deformer -type squash;
// To query the membership of the deformer
deformer -q -g squash1;
// To add additional geometries from your deformer, type:
select -r nurbsCylinder1 ;
duplicate;
// Result: nurbsCylinder2 //
move -r -2.749017 0 0 ;
deformer -e -g nurbsCylinder2 squash1;
// To remove a geometry from your deformer, type:
deformer -e -rm -g nurbsCylinder2 squash1;
Frank Rieder
Re: replace object
on Mar 28, 2010 at 6:39:58 pm
Michiel,
Thanks once again for your answer.
My object has several deformers and motion.
I made a new better object, which I would like to use in
place of the first one.
Frank Rieder
Re: replace object
on May 9, 2010 at 4:10:10 pm
Michiel,
I cannot find the plug.
What is its name?
Frank
Michiel Duvekot
Re: replace object
on May 9, 2010 at 8:41:34 pm
if you use standard deformers that come with Maya that part does not apply to you and you only need to do something like this:
Michiel
http://www.thnkr.com
Frank Rieder
Re: replace object
on May 10, 2010 at 9:53:52 pm
Got it, thanks.
What means -e -g?
