Maya nParticle fill object not working
COW Forums : Autodesk Maya
Bryant Coffey
on Mar 19, 2010 at 6:13:24 am
Alright I create a poly cube, go to the ndynamics menu set then nParticles -> create nParticles -> Fill Object. Nothing happens. I uninstalled Maya 2010 as well as 3ds Max in hopes that the combination might be causing a problem and still nothing is happening. I tried the same combination on another computer and it worked just fine. Took down the active plug-ins and settings made them the same on my computer and it still did nothing. Tried all the other nParticle emitters/creators and they all worked. Every time I try to fill the object I get this message in the status box, which I would assume meant that it attempted to create it.
particleFill -rs 10 -maxX 1 -maxY 1 -maxZ 1 -minX 0 -minY 0 -minZ 0 -pd 1 -cp -dw;
The cube is selected as I'm doing this. Any thoughts/solutions? Let me know, thanks!
Bryant
Michiel Duvekot
Re: Maya nParticle fill object not working
on Mar 19, 2010 at 8:03:38 pm
Turn off Double Walled in the Particle Fill Options. You may have to scroll a bit in the window; it's the last option and easily missed.
Bryant Coffey
on Mar 20, 2010 at 5:54:18 am
I have both tried this with the double walled option on and off... same thing happens both ways. I've also tried a variety of different options on and off to see what happens. Thanks for the response. Any other ideas? Let me know what you think. Thanks.
Michiel Duvekot
michiel@duvekot.ca
on Mar 20, 2010 at 4:18:41 pm
run this from the Script Editor
polyCube -w 1 -h 1 -d 1 -sx 1 -sy 1 -sz 1 -ax 0 1 0 -cuv 4 -ch 1;
particleFill -rs 10 -maxX 1 -maxY 1 -maxZ 1 -minX 0 -minY 0 -minZ 0 -pd 1 -cp;
Bryant Coffey
Re: michiel@duvekot.ca
on Mar 20, 2010 at 4:30:28 pm
Do I just type it in at the bottom or is there a better way to do it? I'm still new to Maya and the I haven't gone in depth too much with the script editor...
Bryant
Michiel Duvekot
on Mar 20, 2010 at 5:48:41 pm
You paste in in the Script Editor and choose Command -> Execute from the menu.
Bryant Coffey
on Mar 20, 2010 at 5:51:58 pm
Thanks man, I'll give it a try when I get back to my place.
Bryant Coffey
Problem Solved.
on Mar 22, 2010 at 4:23:59 am
So I tried your solution by pasting it in and it didn't work. So many people have said the double walled option was the culprit so I tried it on a computer that does work and it took on the same problem as what mine was doing. So I did yet another re-install and after it was done unchecked the double walled option and it filled perfectly. Thanks for all of your help guys -- those who said double walled were correct it must've been a buggy install or something. It works, it's good.
Bryant
stephen weber
on Feb 21, 2017 at 12:56:58 pm
Thanks . Works great for me.
