Maya cannot read this file
COW Forums : Autodesk Maya
jack halsey
on Mar 19, 2010 at 12:37:48 am
Hello
I am importing poser files into Maya because of the superior rendering and 3d effects.
Maya used to be able to easily read the poser files. Now when I click on a poser file it says error reading file and gives me the following on the script editor:
file -f -new;
// untitled //
commandPort -securityWarning -name commandportDefault;
// mental ray for Maya 10.0
// mental ray for Maya: using startup file C:/Program Files/Autodesk/Maya2009/mentalray/maya.rayrc
// mental ray for Maya: setup
// mental ray for Maya: initialize
// mental ray for Maya: using 1 license
// mental ray for Maya: register extensions
// mental ray Node Factory: loaded
// mental ray for Maya: successfully registered
// mental ray for Maya: loading startup file: C:/Program Files/Autodesk/Maya2009/mentalray/maya.rayrc
// parsing C:/Program Files/Autodesk/Maya2009/mentalray/include/AdskShaderSDKWrappers.mi
// generating Maya nodes...
// parsing C:/Program Files/Autodesk/Maya2009/mentalray/include/architectural.mi
// loading C:/Program Files/Autodesk/Maya2009/mentalray/lib/architectural.dll
// parsing C:/Program Files/Autodesk/Maya2009/mentalray/include/base.mi
// loading C:/Program Files/Autodesk/Maya2009/mentalray/lib/base.dll
// parsing C:/Program Files/Autodesk/Maya2009/mentalray/include/contour.mi
// loading C:/Program Files/Autodesk/Maya2009/mentalray/lib/contour.dll
// parsing C:/Program Files/Autodesk/Maya2009/mentalray/include/paint.mi
// loading C:/Program Files/Autodesk/Maya2009/mentalray/lib/paint.dll
// parsing C:/Program Files/Autodesk/Maya2009/mentalray/include/physics.mi
// loading C:/Program Files/Autodesk/Maya2009/mentalray/lib/physics.dll
// parsing C:/Program Files/Autodesk/Maya2009/mentalray/include/production.mi
// loading C:/Program Files/Autodesk/Maya2009/mentalray/lib/production.dll
// parsing C:/Program Files/Autodesk/Maya2009/mentalray/include/subsurface.mi
// loading C:/Program Files/Autodesk/Maya2009/mentalray/lib/subsurface.dll
// parsing C:/Program Files/Autodesk/Maya2009/mentalray/include/surfaceSampler.mi
// loading C:/Program Files/Autodesk/Maya2009/mentalray/lib/surfaceSampler.dll
// parsing C:/Program Files/Autodesk/Maya2009/mentalray/include/Vue7xStream.mi
// loading C:/Program Files/Autodesk/Maya2009/mentalray/lib/Vue7xStream.dll
// displayInfo test 0
// 3Delight for Maya loaded, using 3Delight 9.0.0 win64 (Dec 10 2009) "Antonioni"
// Facial Animation Toolset Version 2.0: Plug-in "GeometryMatcher" successfully loaded.
updateRendererUI;
// Facial Animation Toolset Version 2.0: Plug-in "computeCbsCmd" successfully loaded.
updateRendererUI;
updateRendererUI;
file -import -type "Poser" -rpr "Theministryinterior" "E:/RendersP7/Theministryinterior.pz3";
getenv POSER_LOCATION;
// C:/Program Files (x86)/e frontier/Poser 7 //
// Creating Poser Universe...
// Errnum: -5 Error during BigBang
// Error Enumerating Scene
// Error: Error reading file. //
It should not look at poser 7 but poser pro and had been working fine this past 6 months..
Any ideas? Thank you
