ncloth paper floating to determined final position
COW Forums : Autodesk Maya
Robert Paynter
on Mar 10, 2010 at 9:21:01 pm
So I need to animate numerous sheets paper floating to a determined final resting place. I haven't use maya since v6. I've heard Ncloth was the way to go . Any suggestions or recommendations? I am going to need all the help I can get.
Robert Paynter
Re: ncloth paper floating to determined final position
on Mar 11, 2010 at 4:24:25 pm
I've have created a poly plane applied ncloth changed properties to match another tutorial I saw online for book paper, reversed gravity with a value of 1. Then I created a volume axis field and the turned the turbulence up. It looks great. I plan on reversing the animation to have them fall in and settle into position.
I made this test with flat polys. In the final resting position the poly's will be bent. I am trying this next. So if anyone still has some pointers to make this look good let me know.
Avik Chakraborty
on May 27, 2010 at 2:52:43 pm
Did you do the animation? I'm trying some thing similar only that i just have one falling leaf.
