copy map coordinates to another object?
COW Forums : Autodesk Maya
David Lee
on Mar 4, 2010 at 11:08:12 am
Hi
Is is possible to copy the mapping coordinate settings that you have set up for one object and apply the exact same coordinates to another object?
For example. I have two separate walls each with the same material applied. They are of a tiled pattern.
I want to apply a planar map to one wall just how I like it and then copy that setting to another object (wall)
Thanks in advance
David
Michiel Duvekot
Re: copy map coordinates to another object?
on Mar 5, 2010 at 4:21:51 pm
You can save a preset for the projection node from the Attribute Editor and then use that preset for the new projection node. Presets > Save place3dTexture preset .. and then Presets > MYplace3dTexture > replace.
