edit text in maya 6
COW Forums : Autodesk Maya
dave morgan
edit text in maya 6
on Feb 13, 2010 at 9:09:36 am
How can I edit text font that i already have created?
thanks
Michiel Duvekot
Re: edit text in maya 6
on Feb 13, 2010 at 3:40:43 pm
You can try to find the text node, if it still exists in the scene and set the Text Attribute to something else. This is not very likely to work (it will fail if the number of characters changes) but it might work for small changes.
To find the text nodes, you can use select `ls -typ makeTextCurves`;
Michiel
http://www.thnkr.com
