Newbie, regarding grid texture.
COW Forums : Autodesk Maya
Oskar Westerberg
on Feb 12, 2010 at 1:35:10 pm
In Maya, how do I export the "grid" as a texture? I want something like the picture in this post.
Roberto Etcheverry
Re: Newbie, regarding grid texture.
on Feb 12, 2010 at 3:48:40 pm
Easiest way is to open the UV editor window, save a snapshot, and then use that image as your texture (you can load it on photoshop or simmilar to change looks, color, blur and so on). One of the few things I miss of Max (back when I used it a loooooong time ago) is the "wireframe" material.
Oskar Westerberg
on Feb 15, 2010 at 10:29:42 am
Thanks for pointing me in the right direction. I found out this way of doing it: "Hardware Buffer Render. It's under Window, Rendering Editors. Go to the Render menu in it and then to Attributes to bring up the Hardware Render Globals and set the Draw Style to Wireframe."
