How to attach particles to a polygon object in maya?
COW Forums : Autodesk Maya
Matthew Bowyer
on Feb 11, 2010 at 11:37:05 am
Hi newbie here,
Can anybody tell me how to add particles to a polygon object in maya? A method for it is described here .... http://caad.arch.ethz.ch/info/maya/manual/UserGuide/Dynamics/Particles.doc2...
Specifically...
1
Select the surface.
2
Select Modify > Make Live or click .
3
Select Particles > Particle Tool .
4
Set the desired tool options (see "Setting the Particle Tool options" on page 7).
5
Place the particles on the surface.
6
Deselect the particle object, then select Modify > Make Live.
This deselects the surface as the live object.
It is the rather unhelpful Step 5 "Place Particles on the surface" that is giving me the problems as I don't know how to actually do this.
Any help would be greatly appreciated,
Matt
Michiel Duvekot
Re: How to attach particles to a polygon object in maya?
on Feb 11, 2010 at 4:02:49 pm
step 5 is left-mouse click anywhere on the live surface to place a particle.
Michiel
http://www.thnkr.com
