Maya help needed pls!!!
COW Forums : Autodesk Maya
cristina salageanu
on Feb 6, 2010 at 2:58:29 pm
Hello all!
I am new to Maya and i have a question. If anyone could help me i'd be very grateful!
I've been watching a tutorial on Maya and i've reached to a point where my program doesn't behave as shown: i draw a cube, press 5, it turns to grey, then i right click the cube, choose vertex (the option in the left), and with the selection tool (or move tool) i select a vertex point (one of those mauve points that appeared when i had chosen vertex), and, instead of selecting one point, it selects all the points!
I didn't manage to get this working as it should and it keeps me from moving on.
i uploaded the tutorial in question here http://www.esthezia.net/stuff/0302_Polygonal_components.mov
..and the problem is at time 01:11. i looked and i have the same configuration settings as he does in the video...
and when i select as shown, i get this http://www.esthezia.net/stuff/maya.jpg
Can somebody be kind enough to help, please??
Michiel Duvekot
Re: Maya help needed pls!!!
on Feb 6, 2010 at 6:16:06 pm
You have inadvertently enabled Soft Select. Press the 'b'key to toggle it off.
cristina salageanu
on Feb 8, 2010 at 7:52:36 am
thank you so much! that solved my problem!
