Maya 10 64 on W7 64
COW Forums : Autodesk Maya
Frank Rieder
Maya 10 64 on W7 64
on Jan 28, 2010 at 9:37:54 pm
I cannot import DWG and AI files. Maya doesn't recognize the file.
On XP not 64, same Maya (not 64) I have no problems.
Any ideas?
Stuart Christensen
Re: Maya 10 64 on W7 64
on Jan 29, 2010 at 4:30:56 am
Not sure about DWG files but generally converting CS4 AI files to an earlier version of AI has been covered a lot on this forum. A quick searh should give you some good info. Cheers! Stu
I know alot....but not as much as the other guy.
Frank Rieder
on Jan 29, 2010 at 1:09:01 pm
Stu,
Thanks, but that's not it.
It has something to do with W7 and/or 64bit.
Downsaving doesn't do it.
And it is not just AI, it probably doesn't import any files.
I tried DWG, DXF, AI, EPS.
BTW, the import settings are the same as in on the XP
PC on which importing is no problem.
Michiel Duvekot
on Jan 30, 2010 at 3:03:08 pm
Did you load the translator plug-ins?
Frank Rieder
on Jan 30, 2010 at 4:30:04 pm
Michiel,
Thanks for the help, yes I did load the plug in.
It is all the same as on the XP machine, just W7 and 64bit.
Apparently I am the only one having this problem, guess it
must be something I am doing wrong.
It is just quiet annoying, I have to import everything on the
XP machine, while the W7 is the preferred workstation.
Thanks again.
