Contours_to_mesh nightmare.
COW Forums : Autodesk Maya
Adam Roestenburg
on Jan 28, 2010 at 12:52:04 pm
Hi guys,
I have recently started my first job as an animator as a mining co.
I have been having a few issues with trying to accurately incorporate some of there "data" into maya.
I have been given a whole bunch of contours that make up an ore body. I am trying to generate a mesh that resembles the ore body.
So far, I have tried using nParticles to create a blobby mesh from curve emitters, the results are ok , but they are pushing me to achieve 10m accuracy on the model. Take a look at the contour nightmare I'm dealing with, (this has been cleaned up significantly)
and the results I have managed with blobby's
If anyone has any other suggestions , maybe some sort of fill boundries like procedure or just another approach your input would help me float a little in my first job.
regards
adam.
Michiel Duvekot
Re: Contours_to_mesh nightmare.
on Jan 30, 2010 at 5:13:11 pm
You might look at using the curves to create a wire deformer. Create the deformer when they're all at the same elevation, then move them up. This works reasonably if you're trying to model a segment of a surface. It doesn't work so well for a volume.
But you should really look into getting better data than contour lines. What were they created from?
Adam Roestenburg
on Jan 31, 2010 at 2:40:04 am
Wireframe deformer.
Ok i'll give this a shot. I assume it works like a lattice only referencing the curves to deform the mesh?
I have also been given a extremely high poly block model. Which is unmanageable on the machine I am working with.
I have tried using the NEX plug-in to retoplogize the model, but the mesh has double sided faces and bordering faces, so the tools are not responsive.
Thank you for the suggestion.
adam
