Serious aliasing on final render...
COW Forums : Autodesk Maya
stephen reber
on Jan 19, 2010 at 5:31:08 am
Hey guys. I just rendered out a small project I've been working on and all the edges have some serious aliasing going on, really jagged and not smooth like usual.
The only thing I can think of is that I had to uninstall and re-install .NET frameworks 2 - 3.5 so I could properly install the Unreal SDK.
Other than that, I have no idea what I might have done. I am using the same settings that I have been using.
Any help would be great!
Thanks in advance =]
puneet loona
Re: Serious aliasing on final render...
on Jan 19, 2010 at 1:47:28 pm
if you are using maya software then render on production preset. and if u are using mental ray then adjust few following settings in quality tab;
click to open anti-aliasing qulity tab and increase max samples to 5 . and multipixel filter type to "box" with filter size of 3 by 3 .
stephen reber
on Jan 21, 2010 at 9:44:42 am
Thanks for the help Puneet =]
