tools problem
COW Forums : Autodesk Maya
Patrick Bjoerkman
tools problem
on Jan 18, 2010 at 12:27:46 pm
My problem is that whenever I select a tool: move tool, scale tool etc. the Z,Y and X appears that you can pull in are so long between each other that I have to zoom extreamly long out in order to reach the red, blue and yellow boxes you can move around (X,Y,Z).
Dont know how this happened but if you know the answer please help. Its really anoying.
Michiel Duvekot
Re: tools problem
on Jan 18, 2010 at 5:36:11 pm
You probably hit the + key a few times too often. Press - a few times or check Window->Settings/Preferences->Preferences under Display > Manipulators where you can set the .manipulator scale.
