Degenerate trimming loop
COW Forums : Autodesk Maya
Frank Rieder
on Jan 13, 2010 at 5:24:33 pm
I got this render warning, it's for a drawing I imported manytimes,
how can I fix this?
GAPT 0.5 warn 092052: degenerate trimming loop
GAPF 0.5 warn 092082: triangulation of face # 0 from object New_grippers3|New_grippers1|pasted__RealDWG_Shape_Rep1|pasted____SHELL1|pasted____SHELL1TM29|pasted____SHELL1TM4|pasted____SHELL1Shape4 failed
Michiel Duvekot
Re: Degenerate trimming loop
on Jan 13, 2010 at 10:29:58 pm
The is a warning from the Geometry Approximation module in mental ray which handles tesselation of NURBS surfaces into triangles. It's telling you the trim curve is no good. It's good practice to make sure trim curve have a bit of overlap on the surface; the ones you imported probably don't do that.
© 2018 All Rights Reserved
