audio speed and playback
COW Forums : Autodesk Maya
Margus Voll
on Jan 12, 2010 at 10:29:04 pm
Hi.
I wonder if it is possible to play audio with its native framerate
I have 25 sec audio 48 khz and 16 bit. It should be also 25 sec on maya as it is in finalcut etc.
I can get normal speed on hearing audio if i set speed to 25 fps but on timeline i get waveform for 600 frames not 625 as is supposed to be.
Eny ideaeas how to change default real time 24 fps to 25?
Margus
http://iconstudios.eu
Alvaro Castaneda
Re: audio speed and playback
on Jan 12, 2010 at 11:07:39 pm
Hi Go to
window > Settings/Preferences > Preferences > Settings
in the Time dropdown
I actually forgot :D, had to ask someone here at the studio, :D , been using houdini a lot :D
varomix - pixelEater
http://www.intelianimate.com
Margus Voll
on Jan 13, 2010 at 8:34:56 am
Hi again.
I got it work on 25 f but audio is stil a bit faster 600 frames instead of 625.
Eny ideas?
Margus
Margus Voll
on Jan 14, 2010 at 7:12:22 pm
Hi.
I got the "solution".
Window/Settings/preferences/settings
There is tab which lets you choose frame rate that controls real-time speed.
What i do not know is how to make this setting permanent
Margus
