Ploygon flowing on path repetitivly
COW Forums : Autodesk Maya
Frank Rieder
on Jan 9, 2010 at 11:16:53 pm
I am trying to animat paper going through a printing press.
I created a path and a polygon (sheet) that travels along.
How can I make this to repeat with a certain interval?
Is there a better way than following a path?
Thank's so much in advance.
Alvaro Castaneda
Re: Ploygon flowing on path repetitivly
on Jan 10, 2010 at 3:34:15 am
hi
you can use the motion path several times and just offset the start and end values for the uValue, first select the motionpath and there's the uvalue property
varomix - pixelEater
http://www.intelianimate.com
