Importing Video into Maya
COW Forums : Autodesk Maya
kai gadd
on Jan 6, 2010 at 6:42:33 pm
Hello
I have a new problem now...I want to import a video onto a plane in maya, I have exported from after effects to a taga sequence and a .mov sequence, then re-imported it into maya once as a file and onces as a movie, onto a plane via the colour box, and I can see it fine, but when I tick use image sequence it goes white with a warning node doesnt exist.
What have I done wrong and what do I need to do?
Cheers
Alvaro Castaneda
Re: Importing Video into Maya
on Jan 6, 2010 at 8:42:51 pm
hi
maya needs a "special" naming for using image sequences, rename or re-export your sequence and name it like this.
mymovie.0001.tga
the number needs a dot at the beginning and that will work
varomix - pixelEater
http://www.intelianimate.com
kai gadd
on Jan 6, 2010 at 9:54:44 pm
yeah thats what I have been doing and it doesnt work, in after effects it keeps putting [####] everytime aswell, even when I set it up as my custom one aswell :S
kai gadd
on Jan 8, 2010 at 1:54:09 pm
Got it working now I rendered it as an avi and works fine :D
kai gadd
on Jan 8, 2010 at 2:01:55 pm
just another problem now, I am rendering in mental ray, the video works but then when I go to render it isnt showing up what do I need to do?
Alvaro Castaneda
on Jan 8, 2010 at 4:08:42 pm
Mental ray has issues with some image formats try using tiff instead, I know it hates pngs :D
kai gadd
on Jan 8, 2010 at 5:11:21 pm
That didnt work either its gone back to showing just a white panal and saying the node does not exist, even when I name the file in tif or taga like you said ill just have to try and track it in
