Wierd Rendering results
COW Forums : Autodesk Maya
kai gadd
on Jan 4, 2010 at 5:17:33 pm
Hello
So with my scene I am rendering by right clicking my file and entering render, my camera is set up to 1024 by 576 pal 16:9 when I render it out via batch render it comes out fine but it takes twice as long to do it, however this way it is quicker but squashes it, when I strecth it back to 1024 by 576 it looks fine, I have tried doing the dos way but doesnt seem to work, anyways it doesnt seem to be a big problem atm but I would like to know why it is doing this and how I can stop it from doing it?
Cheers
P.s heres how the pictures are turning out
and heres when I stretch it to fit to how I want it to look
Franz Palomares
Re: Wierd Rendering results
on Jan 5, 2010 at 1:13:07 am
Just off the top of my head, it looks like the pixel aspect ratio is wrong.
I believe it should be set to 1.
kai gadd
on Jan 5, 2010 at 2:08:08 pm
the pixal aspect ratio is set to 1 however the device aspect ratio is 1.778 does that need changing?
Franz Palomares
on Jan 5, 2010 at 4:39:27 pm
I never really touch the device aspect ratio and it's set to 1.333 on my computer. Try changing the device aspect ratio to 1.333 and see what that does.
kai gadd
on Jan 6, 2010 at 6:28:21 pm
thats made it even shorter. I gave it another go and it seems to work now ...odd
Alvaro Castaneda
on Jan 6, 2010 at 8:52:28 pm
hi
first of all, I think you're using a weird resolution
as far as I know there is no resolution like that for PAL, I think you are trying to render at HD resolution which actually doesn't care about NTSC or PAL anymore
PAL = 720 x 576 aspect ratio 1.333
PAL = 768 x 576 aspect ratio 1.000
my guess is you are trying fo HD720
HD720 = 1280 x 720 aspect ratio 1.777
maya has presets for all that
hope that helps
varomix - pixelEater
http://www.intelianimate.com
kai gadd
on Jan 6, 2010 at 10:03:12 pm
Ahh right cheers, I always thought 1024 by 576 is widescreen for pal
