HDR FX1 1440x1080 FILMBACK/CCD dimensions for MAYA Please!!!
COW Forums : Autodesk Maya
Luis Echenique
on Dec 22, 2009 at 2:53:40 am
Does anyone out there know the EXACT size if the CCD on a SONY HDR-FX1 in milimiters? I am doing a 3-D match move for a sequence I shot on my FX-1. I am using a software called Maya and need to know the size of the filmback wich, in this case, refers to the size of the CCD. The average filmback size for 35mm is 9.875 x 7.351. I think I need it measured to the thousandths decimal. The 1/3" the manual gives is not going to cut it. Anyone have this info. Have not been able to find it anywhere. Chris any thoughts?
Would the same measurements would be used for DV?
I need the filmback/CCD dimensions, the CAMERA aperture.
Not the standard 1/3" 1,170,000 pixel figures you see in the manual. I already checked that.
For an instance the cannon XL-1 Specs are:
Chip size- 6.08 X 5.00 mm
Image area- 4.82 X 3.64 mm
Thanks.
-Luis
Michiel Duvekot
Re: HDR FX1 1440x1080 FILMBACK/CCD dimensions for MAYA Please!!!
on Dec 22, 2009 at 2:56:53 pm
http://en.wikipedia.org/wiki/Charge-coupled_device#Sensor_sizes
Michiel
http://www.thnkr.com
Luis Echenique
on Dec 22, 2009 at 6:57:08 pm
Thanks, but for some reason those numbers wont work. I heard the capture size is somehow smaller than the size of the chip. I need the Exact numbers. But Thanks anyway. Probably from some other users of the FX1 that had done matchmoving succesfuly...
