object/material ID renders as in max?? via rla/exr
COW Forums : Autodesk Maya
manojit ghose
on Dec 18, 2009 at 1:56:23 pm
in 3dsmax we can assign object ID or material ID to preferred objects and render out separate channels for them rendering via rpf/rla/exr.
does anyone know anything similar in maya.
PS: i cannot use passes, as it gives seperate layers, the requirement is so that i need it in one image, as channels.
manojit
MG
manojit ghose
Re: object/material ID renders as in max?? via rla/exr
on Dec 18, 2009 at 2:45:29 pm
ok i got it, used pass contribution maps and rendered out exr.
MG
Stuart Christensen
on Dec 19, 2009 at 7:35:12 am
Cool! STU
I know alot....but not as much as the other guy.
