3D matchmove with downconvert footage
COW Forums : Autodesk Maya
Ori Cerro
on Dec 17, 2009 at 10:46:30 pm
I'm planning a sequence that needs a 3D matchmoving.
I will record in the DVCPRO HD format, but then I would like to downconvert to uncompressed sd for working it.
My question is: If I do the matchmove in sd, I will need to change the aperture settings for the virtual camera in maya?
The aspect ratio of the original and converted footage will be the same, the diference is that the original has double resolution than the converted footage.
Michiel Duvekot
Re: 3D matchmove with downconvert footage
on Dec 17, 2009 at 11:38:52 pm
No, a change in resolution does not affect aperture.
Michiel
http://www.thnkr.com
