Maya trying to access my cd rom drive on Macbook Pro
COW Forums : Autodesk Maya
Chris Lee
on Dec 12, 2009 at 7:02:15 pm
Almost everytime i try to access an object in Maya it tries to access my cd rom drive. I am running Os x 10.5. Anyone have any ideas. Of course i get the beachball and my computer kinda glitches. It is seriously slowing down my workflow. Any help will be greatly appreciated
Michiel Duvekot
Re: Maya trying to access my cd rom drive on Macbook Pro
on Dec 12, 2009 at 8:05:30 pm
What, specifically do you do when you "try to access an object in Maya". I'm not sure what that is.
Do you select a poly mesh by clicking on it in the viewport, do you select File->Create Reference... from the main menu?
Please be as detailed as possible.
Michiel
http://www.thnkr.com
Chris Lee
on Dec 12, 2009 at 8:11:54 pm
By CLicking on it on the viewport
Chris Lee
on Dec 16, 2009 at 4:08:43 am
any more thoughts on this
Michiel Duvekot
on Dec 12, 2009 at 10:44:58 pm
while Maya is running open a terminal and take a look at what files Maya is trying to access with fs_usage
sudo fs_usage -w -f filesys
Michiel
Chris Lee
on Dec 12, 2009 at 11:36:09 pm
here is the report
http://www.djmizu.com/Terminal%20Saved%20Output.txt
thanx
Michiel Duvekot
on Dec 16, 2009 at 7:50:14 pm
I don't see Maya trying to access the DVD drive in this log file. Did you notice Maya attempting to do so?
Michiel
Chris Lee
on Dec 16, 2009 at 8:23:24 pm
my drive tries to spin if there is not a disc, and spins a disc if there is one in it
Michiel Duvekot
on Dec 20, 2009 at 4:58:55 pm
That's not quite what I meant. I wanted to know what you observed while running the test.
If I look at the log file, I don't see any application making any attempt to access the drive while you were running fs_usage. Did you notice that while you were running fs_usage, something still tried to access the drive, even though it didn't show up in the log file?
Michiel
Mario Luis Moura
on Feb 21, 2010 at 5:08:10 pm
I have the same problem. Did you guys got any solution to this?
Mario Moura - editor
Marcin Bar
on Nov 2, 2010 at 4:48:44 pm
Hello. Do anybody solved this problem. I checked fs_usage and I didn't notice nothing special. This is very annoying. Please any help. Thanks
alex ezorsky
on Oct 11, 2011 at 3:50:53 pm
Me too! What gives?
