sound rendering in maya
COW Forums : Autodesk Maya
soumya raje
on Dec 11, 2009 at 5:48:00 am
i am not able to render video with sound, Maya 2009
the sound plays within the scene and also in playblast
but when i rendered it as AVI it is not there
pls help me
Paul Roper
Re: sound rendering in maya
on Dec 11, 2009 at 7:30:32 pm
Didn't even know Maya could render to AVI. It's generally a bad idea to render as a movie file instead of an image sequence; if the rendering fails while outputting a movie, the entire movie will probably be unplayable. If it fails/crashes after rendering 950 frames of a 1000 frame sequence, you just need to re-render the final 50 frames.
You'll need to add the sound using another application - Maya's really not built for producing final output with sound - it's part of a production pipeline before it gets tweaked/comped/graded/edited etc. for final output.
soumya raje
on Dec 11, 2009 at 7:35:16 pm
thanks for the insight.. i'll use your advice :)
