replicating mapping
COW Forums : Autodesk Maya
David Lee
replicating mapping
on Dec 8, 2009 at 6:01:20 pm
Can someone please tell me if I can do the following?
I have two separate objects each with the same material attached, (a concrete pattern)
The two objects are different sizes. What I want to do is assign an automatic mapping to one object and adjust the scale to suit the grain of the concrete pattern.
The other object has the same material applied and so should look the same scale etc. Its way too big a scale and appears to be so because the object itself is bigger.
Is there anyway I can make a globally scaled pattern cover the two objects and have them look identical?
© 2018 All Rights Reserved
