Possible to use snap to point to connect object to boujou track?
COW Forums : Autodesk Maya
Hairston Williams
on Dec 3, 2009 at 7:04:30 pm
I was wanting to know if its possible to use a snap-to tool to connect a 3d object to a previous boujou (matchmover) tracked tracker point or multiple tracker points? I figured it would be easier to do that than lining everything up. Can I do this? Is it possible to connect it to multiple track points or just one or neither?
Thanks in advance,
Hairston
Alvaro Castaneda
Re: Possible to use snap to point to connect object to boujou track?
on Dec 4, 2009 at 4:46:07 pm
yes you could, you could make a point constraint to one or multiple points, or just parent the object to the point, that works
varomix - pixelEater
http://www.intelianimate.com
