Voice sync
COW Forums : Autodesk Maya
kai gadd
Voice sync
on Dec 3, 2009 at 11:29:20 am
Hey
I have been creating my first human character animation, and I have had a go at voice syncing my character, it looked ok in maya but when I rendered it as taga, then imported both the images and audio into after affects it seems to go out of sync.
Is there a better way of rendering the animation in maya?
Also is there any free plugins that will make this process easyier to voice sync?
Heres an example of what I am doing.
Bruce Talking from Kai Gadd on Vimeo.
Kai
Alvaro Castaneda
Re: Voice sync
on Dec 4, 2009 at 4:44:41 pm
Hi
Check you r frame rate (FPS) in both after and maya, that might be the problem
maya by default uses 24 fps and after effects uses 30 fps, and any footage as image sequence you import to after effects comes as 30 fps by default,
that might be
varomix - pixelEater
http://www.intelianimate.com
kai gadd
Re: Voice sync
on Dec 15, 2009 at 6:30:45 pm
Thanks for that,
That doesnt seem to be the problem, I have noticed now that the later half of my animation is in sync but the first half is abit jumpy, any suggestions to what it could be?
Kai
