All objects are blocked
COW Forums : Autodesk Maya
ali sabag
on Nov 27, 2009 at 6:35:46 pm
please....somehow all objects are blocked in my Maya...if i create a new polygon Maya will not allow me no select any face,Vertex or Edge...even if i load a current file I've been working will allow me to select the object but when i go to vertex (or any selection option) will just show me the vertexs but will not allow me to select any vertex or modify it.....if i go to any option like split polygon, it will not do anything at if there wasn't anything there.
So weird!!!
sumesh khanna
Re: All objects are blocked
on Nov 28, 2009 at 10:05:19 am
chk whether whether select by hierarchy is on,if on change it to selct by object type.You will find it in status line
James Willis
lightwave files into Maya
on Jan 6, 2010 at 8:02:41 pm
I currently work with two application; Lightwave 9.5 and Maya 8.5.
I exported my lightwave to an OBJ file and imported it into Maya. Is there any way I can break it apart to do edits in maya?
Alvaro Castaneda
Re: lightwave files into Maya
on Jan 6, 2010 at 8:40:03 pm
use MESH > SEPARATE to break it up into individual objects
varomix - pixelEater
© 2018 All Rights Reserved
