splash.dll error message
COW Forums : Autodesk Maya
Sam Behrens
on Nov 20, 2009 at 11:24:29 pm
I'm new to Maya. I have it loaded on a Win7 laptop. I'm getting an error message at start-up. I get 3 of them, all saying the same thing, "This program cannot start because splash.dll is missing from your computer. Try reinstalling the program to fix this problem." I close all three, and then the program opens, and as far as I can tell, operates normally. I tried reinstalling the program with no change. Anybody having the same trouble? Is it a glitch with Win7?
Many thanks,
Sam Behrens
Charis Malik
Re: splash.dll error message
on Dec 3, 2009 at 2:44:51 pm
hi, here is the solution Autodesk gives:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13937843&l...
it says that problem appears when u have 3ds max and maya 2010 in the same computer.
but i don;t know what to do? with that.
Issue
Maya.exe cannot start because splash.dll is missing.
Solution
This error will happen if you have Maya 2010 and 3dsMax 2010 on the same computer. You will need to set the following environment variable for Maya:
set MAYA_DISABLE_CIP=1
to set that where?
from where?
i don;t undertand.
Sam Behrens
on Dec 7, 2009 at 4:01:48 am
Charles, thanks for the reply. I can't figure it out. Still can't find the solution, but it's not keeping me from using Maya, so no biggie.
S. Behrens
Gilton Jose
on Dec 31, 2010 at 6:35:39 am
just go to your system environment variables and set MAYA_DISABLE_CIP and value is 1
Ahmed Osama
on Jan 10, 2010 at 4:36:14 am
friend,
paste this code in a text file and rename it with Maya.env
notice the M in maya is a capital letter
paste this file in the following path:
Documents\maya\2010
ok to the replacement message
restart maya and this should fix it
shubham kapoor
on Dec 1, 2011 at 8:08:03 am
hello sir,
thanks for your support, even i was facing the same problem which have been sought out now. i just did as you said and now its working fine and no more pop up comes up.
thanks
shubham kapoor
Behlul Numan Ozdemir
on Nov 10, 2010 at 4:58:03 pm
Thanks, i have the same problem and solved with this solution.
Charles Phillips
on Apr 23, 2010 at 5:52:34 pm
I had the same issue and didn't find the .env file. I did check in system32 and saw that infact the splash.dll file was missing. After I downloaded it and moved it into the system32 folder under windows I no longer has the error code showing up. You can download it here ---> http://www.dlldump.com/download-dll-files_new.php/dllfiles/S/Splash.dll/2,1...
Sam Behrens
on Apr 23, 2010 at 11:47:33 pm
That did it! Thanks Charles.
S. Behrens
Steve Lee
on Sep 29, 2010 at 2:29:08 am
Thanks, Charles! Your advice fixed the same issue for me.
gary schofield
on Feb 10, 2012 at 9:06:59 am
your reply to this thread is still benefiting people, better than autodesck technical support...im so pleased to get rid of that dammed error message, thanks
