Varomix - Particles Basix Help
COW Forums : Autodesk Maya
Chris Carter
on Nov 18, 2009 at 12:11:39 pm
I watched the particles basix video by varomix and tried doing everything step-by-step exactly as shown in the video. But when i hit render, particles doesn't show up in the preview window. why is that? please help?
Alvaro Castaneda
Re: Varomix - Particles Basix Help
on Nov 18, 2009 at 3:56:32 pm
Hi
Thank you for watching my tutorial
Maya software renderer doesn't render point particles, change the renderer to mentalray, right there in the render view select mental ray from the drop down
varomix - pixelEater
http://www.intelianimate.com
Chris Carter
on Nov 19, 2009 at 11:13:04 am
Thanks for your prompt reply. I've been told the same thing by others as well. But i've tried hardware render, mentalray, pretty much every single options available in the drop down menu, but i still don't see the particles in the preview.
I've checked the plug-in manager and everything's fine. Or is it because i'm using a different version of Maya? I'm currently using Maya 2010, but it's odd if Maya 10 can't even render point particles while older versions can.
Is there any other possibilities that something needs to be changed somewhere? Any settings that needs to be changed or modify etc?
