Can someone help with scale tool?
COW Forums : Autodesk Maya
David Lee
on Nov 14, 2009 at 9:22:24 am
I am going to go mad if I don't crack this.
I have created a simple cylinder in a totally new scene.
create-polygon primitives-cylinder reset settings and create.
set height to 20, subdivisions axis 20, subdivisions height 5, caps 1
Into component mode and select a whole ring of vertices in the middle of the cylinder
press r for scale tool
Now here's where it goes wrong and I am following written instructions from a manual here.
I want to uniformly scale the ring of vertices equally in the x and z axis.
What I AM getting is an elongated scale in the x or the z axis.
I just want to scale the ring of vertices out in a larger radius but its not working.
Can anyone help before I throw it out the window :-)
Dave
David Lee
Re: Can someone help with scale tool?
on Nov 14, 2009 at 3:21:26 pm
Panic over, I found out what it was, I had reflection set in my scale tool settings. dont know why that was on. Phew, I wish I knew more then I made out. :-)
