Deformer problem
COW Forums : Autodesk Maya
David Lee
Deformer problem
on Oct 27, 2009 at 7:48:01 pm
Please can someone help?
I have read the threads and I cannot find the answer I am looking for.
I am trying to remove the deformer that is attached to my cylinder.
I have used the bend non linear deformer to bend a cylinder to make a chair leg. I then made 3 more instant copys and rotated the cylinders in place. Thats when all my objects went wild because I moved or rotated the objects without moving the deformers.
How can I make the objects unique again. I just want them as polygon objects and have no further need of the deformers.
Thank you
Matt Nielsen
Re: Deformer problem
on Oct 27, 2009 at 9:45:49 pm
Select the object and under Edit > Delete By Type > History. This will remove the connection between the deformer and the geometry.
Hope this helps
Matt
David Lee
on Oct 27, 2009 at 11:22:23 pm
Thank you Matt, that worked just great.
