Mirroring Problem
COW Forums : Autodesk Maya
kai gadd
Mirroring Problem
on Oct 22, 2009 at 4:47:05 pm
Ok I am tryna mirror a model, and for some reason all of a sudden it mirrors it on the +x instead of -x iv looked at the settings and its set to -x and iv also snapped all the vertices on the line but everytime i go to mirror it does it on the right side of the image
Can anyone help?
Adam Benson
Re: Mirroring Problem
on Oct 27, 2009 at 12:02:51 am
Sounds like the axis of the actual object may be turned around. Try Freezing your Transformations, or Grouping the object first.
Adam Benson
Visual Effects Artist/Musician/Sound Engineer/Editor
http://www.SleepDeprivedProductions.com
http://www.SleepDeprivedFilms.com
kai gadd
on Nov 2, 2009 at 12:33:07 pm
Thanks pal, the freezing transformations did it!
