objects follow contour of other object?
COW Forums : Autodesk Maya
jim cascarina
on Oct 2, 2009 at 9:22:15 pm
is it possible to have one object constrained to the shape of another object.
for instance I want a cube sitting on top of a bigger sphere i want to animate the cube in z but the cube need to follow the curve of the cube?
I hope that makes sense. thanks in advance
Michiel Duvekot
Re: objects follow contour of other object?
on Oct 2, 2009 at 9:58:10 pm
[Animation] Constrain->Geometry and [Animation] Constrain->Normal do that for you. Select the target surface, then the object you want to constrain, then run the two commands.
Michiel
http://www.thnkr.com
jim cascarina
on Oct 3, 2009 at 9:31:14 am
Thank you so much, for the speedy and helpful response.
constrain normal is the one, it's a perfect simple and elegant solution to my projects issue.
thank you
