Render Farm
COW Forums : Autodesk Maya
Adam Benson
Render Farm
on Sep 28, 2009 at 8:28:23 pm
Can anyone suggest a good online render farm? I need one that will do maya, mental ray, maya fluid dynamics and everything else. I've been using RebusFarm, but unfortunately for whatever reason (and they can't figure it out either) every time I send them a file it fails to render. All that aside I need a good render farm company!! BADLY!! Anyone? Anyone?
Thanks all!
Adam
Adam Benson
Visual Effects Artist/Musician/Sound Engineer/Editor
http://www.SleepDeprivedProductions.com
http://www.SleepDeprivedFilms.com
Adam Benson
Re: Render Farm
on Sep 28, 2009 at 9:26:17 pm
I will say this. The guys at Rebus Farm have been enormously helpful! Whenever there has been an issue they work quickly to resolve it. This has meant updating their software, et cetera! Whatever issue my files were having they were able to resolve and have subsequently saved the day! I highly recommend Rebus Farm to anyone. Their prices are great and their service includes a plug-in that works directly from Maya. It's like rendering completely within your own system! Check them out: http://www.RebusFarm.com
Adam Benson
Alessandro Paolin
Re: Render Farm
on Nov 14, 2011 at 3:45:01 pm
Hi Adam!
Saw your post while surfing the internet looking for a solution to my problem with maya and rebus farm: I have an error with layers: I imported from the reference editor all the models, selected all from the scene and putted in a new layer; then I tryed to select all from the Hypergraph and putted all in the previous (new) layer, I’ve got just the master layer to render, but I still have that message about a referenced layer: "You may only have one enabled layer if you render a single frame" and a warning message "Warning: 'filename:defaultRenderLayer' is a Layer from a referenced scene and is not allowed to be the current layer" .I can’t figure out what I can do in order to fix it...any suggestion?
Thanks. Bye!
Alessandro Paolin
