How to rotate objects around a pivot
COW Forums : Autodesk Maya
David Lee
on Sep 23, 2009 at 7:28:05 pm
Hello I am sorry if this has already been answered before but I am a complete newbie on Maya. I wanted to rotate objects around a central pivot point at 360 degree like creating numerals on a clock.
I know how to do this in max but this MUST be possible to do i Maya yes?
Alvaro Castaneda
Re: How to rotate objects around a pivot
on Sep 23, 2009 at 8:42:34 pm
Hi
you can change the pivot of any object by pressing the insert key and moving it, then press again to exit of pivot editing mode, and then rotate your objects
and theeen scream yeaaah!!! really loud :D
varomix - pixelEater
http://www.intelianimate.com
David Lee
on Sep 23, 2009 at 9:23:35 pm
Thanks for the reply but I am using a mac and there is no insert key.
Alvaro Castaneda
on Sep 23, 2009 at 10:20:10 pm
I think on mac is the home key
David Lee
on Sep 23, 2009 at 10:42:05 pm
Thanks Alvaro that worked fine.
It rotated around my new pivot but what I wanted was to polar array the object around the pivot say.... 12 times, 360 degrees around the pivot point like you can do in 3ds max
Thanks for your kind help
Alvaro Castaneda
on Sep 23, 2009 at 11:02:36 pm
glad that worked, use DUPLICATE SPECIAL options for the duplication
that's under EDIT > DUPLICATE SPECIAL options and set the number of copies
and the degrees each will turn and that's it
David Lee
on Sep 23, 2009 at 11:20:49 pm
Thanks so much, that worked too.... I feel that I have learned something today as I have only just started learning Maya.
Strange because I know it can do all that Max can do.
Thanks again
