Mirror Cut tool suddenly gives error
COW Forums : Autodesk Maya
Aye Haich
on Sep 15, 2009 at 3:02:10 pm
Hello all,
I have created half a car model in maya, and would like to mirror it (Mirror Cut).
After trying to apply the mirror cut, I get the following error message:
//Error: no object matches name: mirroredCutMesh1.allowTopologyMod
This error just started appearing, im freaking out because I have to hand in my model for class in 2 days.
Please help, thank you.
Matt Nielsen
Re: Mirror Cut tool suddenly gives error
on Sep 16, 2009 at 10:11:46 pm
Out of curiosity why are you using Mirror Cut if you are just trying to mirror and attach the geometry?? You have a lot of different options open to you e.g. Mirror geometry, you could duplicate the object yourself then scale it negatively along one of the axis (Note if you do this you will have to reverse the direction of the face normals. Another useful tool is Edit > Duplicate Special > Options. Its basically the same method as above but you set the options in the Option window and it reverses the normals for you. The only problem with doing the latter two is that you will have to combine the objects together using Mesh > Combine then merge all the central vertices. I would recommend trying the Mirror Geometry tool first. Good luck with the assignment and I hoped that this has helped.
© 2018 All Rights Reserved
