Reposition the plane in maya after matchmoving in boujou?
COW Forums : Autodesk Maya
Hairston Williams
on Sep 6, 2009 at 11:03:44 pm
Hi everyone,
I was just wanting to know what I need to do in maya in order to move the orientation of my plane after I import footage from boujou. I know you can do this in boujou but i think boujou gets it wrong alot of the time. Could someone explain how you might go lining up your plane so that your geometry is portrayed correctly when you blend it with the live action plate? Thanks!
Hairston
Alvaro Castaneda
Re: Reposition the plane in maya after matchmoving in boujou?
on Sep 9, 2009 at 6:11:55 pm
You can, just make sure you are moving the main group
if not you track will break
varomix - pixelEater
http://www.intelianimate.com
