Fatal error help...
COW Forums : Autodesk Maya
stephen reber
Fatal error help...
on Sep 2, 2009 at 3:41:27 am
Hey all...
I'm trying to render out a project and I keep getting the error...
// Error: *Fatal* (mental ray) : mental ray encountered a fatal error. The system may have become unstable. Please save the scene and exit Maya.
And in the MEL script editor...
DB 0.4 fatal 041008: attempt to access null DB tag
Right now, my project is at 24 mb. If this is the problem, how can I reduce the size??
If not, any thoughts? I've tried exporting and importing the project, but not go.
Thanks in advance...
Stephen =]
Michiel Duvekot
Re: Fatal error help...
on Sep 2, 2009 at 3:19:57 pm
There are two common causes for this error: You're eithe rusing a corrupted material or mental ray is flushing required scene elements from the database because it's running out of memory.
To exclude cause #1, simply assign a basic Lambert to all objects and see if the error goes away. If it doesn't, proceed to troubleshooting memory errors. I'd need more information than you provided to help you do that. The log file will tell you how much RAM was used, and the first thing I'd recommend is to check is the memory option in the mental ray Render Option window. Is Auto Memory Limit on for example?
Some common solutions to memory issues are: enable the 3GB switch under 32 bit windows, disable raytracing if you do not need it, break very large objects (especially those that surround the scene) into smaller chunks, replace omnidirectional light with a spotlight.
stephen reber
on Sep 8, 2009 at 12:16:19 am
Hey Mike =]
Thanks for the help! It was a memory problem... kinda. I made the mistake of not clearing out the history on all my objects. From what I gather, alot of history on alot of objects eats up alot of memory?? Did I hear correctly?
Thanks again for your help...
Stephen =]
