Export MAYA to after, Help !!!!!!!!!!!!
COW Forums : Autodesk Maya
renaud hericord
on Aug 27, 2009 at 9:31:36 pm
Hello to all
I have a scene MAYA registered .Mb, I would like to export my camera and my 2null in .Mapourles after putting in and retrieve my cam elements and address etc.
PS: I render my scene with mental ray
The thing is said AFT ca:
File contains unknown nodes or date. To preserve the information, Upgradability the current file can not be changed.
I look at my script editor and he told me ca, Please it is very important help me :
/ / Error: Line 1: Plug-in, "mayall_maya70.Mll ", Was not found on MAYA _plug_in_path. / /
/ / Warning: Line 1: Unrecognized node type for node 'vectorrenderglobals'; preserving node information during this session. / /
/ / Read file in 5 seconds.
Requires "as" "8.5 ";
Requires "vectorrender" "7.0 to 3.209 - Cut 200,612,170,502 ";
Requires "mayatomr" "8.5.1.3m - 3.5.6.7 ";
Requires "mayall_maya70" "0.9.1 (beta) ";
/ / Warning: Line 1: Unrecognized node type for node 'maxwellglobals'; preserving node information during this session. / /
/ / Warning: Line 1: Unrecognized node type for node 'maxwellenvironment'; preserving node information during this session. / /
/ / Warning: Line 1: Unrecognized node type for node 'bibendum_old_maxwellglobals'; preserving node information during this session. / /
/ / Warning: Line 1: Unrecognized node type for node 'bibendum_old_maxwellenvironment'; preserving node information during this session. / /
/ / Warning: Line 1: Unrecognized node type for node 'skinsuite_275_skinning_main:Maxwellglobals'; preserving node information during this session. / /
/ / Warning: Line 1: Unrecognized node type for node 'skinsuite_275_skinning_main:Maxwellenvironment '; preserving node information during this session. / /
/ / Warning: Line 1: Can not perform bibendum_in_efecto:Polysoftedge1 on selection / /
/ / Warning: Line 1: Can not perform bibendum_in_efecto:Polysoftedge2 on selection / /
/ / Warning: Line 1: Can not perform bibendum_in_efecto:Polysoftedge3 on selection / /
/ / Warning: Line 1: Can not perform bibendum_in_efecto:Polysoftedge4 on selection / /
/ / Warning: The scene you are referencing contains as. Ensure that you must as the globals in this scene are set as required,
Since the values in the referenced node as globals are not used. / /
/ / Error: No object matches name: Strokeglobals.Wraph / /
renaud hericord
Re: Export MAYA to after, Help !!!!!!!!!!!!
on Aug 27, 2009 at 9:49:44 pm
c'est bon j'ai trouvé la solution !!!!!
je prends ma camera et mes deux null et je fais exporter selection, je les enregistre en .mb
puis je crée une nouvelle scène et j'importe la scene en .mb que je viens de faire
puis j'enregistre ma scene en .ma et le tour est joué !
